Search the Knowledgebase |
Browse by Category |
| 2005 XLR-V: Service Information: Cross Drilled Rotors |
| User Opinions (3 votes) |
100%
0%
Cross-drilled brake rotors (fig. 16 -attached) are being used on the 2005 1/2 Pontiac Grand Prix GXP, and available on the 2005 Chevrolet C6 Corvette and the upcoming Cadillac XLR-V.
If required, these brake rotors can be machined on a lathe in a similar manner to standard rotors.
TIP: When cutting rotors, use positive rake tooling on the lathe (fig. 17 - attached). Positive rake tooling requires less cutting pressure, reduces chatter, and improves surface finish. When setting up the brake lathe, be sure to use a vibration dampener/silencer.
Using SI procedures, apply a non-directional finish to the rotor surface after machining by using a sanding block and 150-grit aluminum oxide sandpaper.
- Thanks to Fred Tebbets and Rob Coultes, GM Techlink, May 2005
| Visitor Comments |
