Need some help/advice on where to order parts or find repair shops in central texas. Have a 2006 with 62K miles and in great shape. Just need a few small repairs done.
Les
I need the housings for the turbo air filters that sit above the radiator. This car keeps eating batteries as well. Someone suggested a trickle charger or cranking every couple of days. I rarely drive it.
thanks
Les
well it should not die every couple of days. it usually will be fine for a once a week drive .Yes the trickle charger is pretty much a must. Dont know about Turbo? filters. Car does not have turbo. you can find used filter housings from time to time on ebay . Most of them break at the little mounting hole tab. I repair and reinforce that if thats the problem. If its the latch part you can get the vette bas and use the xlr tops or use the vette tops . they just have one end cut off for more flow. PM me a photo and I will find you some if I dont have any
