Rexster
l remember you had a newer radio installed in your XLR. I thought you had to leave the CD slot in the car. Did you ever install a camera? The reason for the 4500 model was for the two camera's. I wanted a CD because of the sound quality.
V Happy
pS you are correct about the heads up station display.
How did the installation go with the Kenwood DNX995S ? Any issues? I'm considering doing the same thing.Scheduled to have a Kenwood DNX995S + front & rear cameras installed a week from tomorrow
New XLR owner here, the car is a 2007 Passion Red and was purchased for my wife. Looking to replace the factory radio/CD/XM unit with a newer double DIN that incorporates rear view camera, but the installers I've spoken to thus far use a kit that includes a plastic replacement front panel around the air vents, radio opening and HVAC controls. This solution is not preferable since I'm not interested in losing the beautiful eucalyptus wood trim surround. Anyone with a different experience?
Just finished installing a Kenwood DDX8906S in my 07 XLR-V. I purchased through Crutchfield and bought the install kit which included that plastic front panel. I used the supplied wiring harnesses but did not use the plastic panel, instead used the factory eucalyptus wood panel and installed the unit using the existing factory brackets which are attached to the head/ cd changer unit. I simply unscrewed the brackets from the factory radio and screwed them on to the Kenwood unit. The hardest part was making sure the Kenwood lined up vertically to match the factory front panel and drilling holes in the brackets (2 brackets, one on each side) to screw them on to the Kenwood unit Also had to buy a double din faceplate adapter for the Kenwood as the face of the Kenwood is about 1/2 inch narrower than the factory opening. I agree with you, no way I wanted to lose than eucalyptus wood face panel.
