Brakes Hard Left
Well they're making some progress on the XLR brake issue. They tell me they put in a brand new ABS module they had built by some firm and it comes with a warranty. When I get the car back I'll ask about the company that provided the unit and post their info on here, maybe it will be of use to someone else. The mechanic says the brakes are no longer locking up but now the car is throwing a code for the Yaw Rate Sensor. He checked the sensor and it is working fine. He thinks it may be a connection issue. He's looking into it. More to come.
I mentioned the possibility of you have a yaw sensor problem in my reply at #17. Could be the root cause. If the ABS system 'thinks' it is detecting an out of control change in direction (ie rapid yaw), it will command a very sharp and abrupt front brake apply, to attempt to reduce the severity of the situation. Seems to match your symptoms. Y'know, maybe you could simply disconnect the yaw sensor, revert to the original ABS module and see how you get along.
You're correct! The mechanic finally got an erratic signal from the yaw sensor while sitting at idle in park with the scan tool connected. He replaced the yaw sensor and everything then checked ok with the scan tool. I picked the car up that afternoon and have since put 100 miles on it with no problems so far. Hopefully my problems are solved. I will follow up with more info about the company that provided the new ABS module. Thank you to everyone that posted info on here to help with my situation.
Torque Shop
