onalaska
Left the house and got this message in the DIC about 5 miles down the road. Checked the gauges and the temp was on the left peg showing no temp at all. The engine fan running at high speed, but the radiator hose had no pressure on it at all and the engine was not hot. Checked the engine temp sending unit connector and it looked OK. Plugged in my scan tool and the engine temp. Was reading normal. Cranked it back up today and immediately had the same message on the DIC. Engine cooling fan on high. After running about 10 min the message went away and noticed the temp gauge was reading normal again. Engine fan turned off and it has been normal since. What happened? Loss of comm? From the ECU? Scan tool was showing normal temp. but the ECU thought it was hot even though the gauge showed it was cold. At least I know I didn't overheat the engine.
