Help! Front LED / HID Bulb Retrofit
6444johnf
Atlanta
2008 XLR
I’m considering replacing the “Daytime Running Lights” withdual color LED & the “Fog Lamps” with HID has anyone experienced thisretrofit also what are the potential problems and advice. Making the entire front lighting system consistent,I think, will enhance the appearance.
Search is your friend!!
Foglight replacement with HID is fairly simple. This link to the thread here will help you out:
https://www.xlr-net.com/forums/cadillac-xlr-technical-discussion/4404-hid-fog-lamp-install.html
As far as changing the DRL's with the dual color LED's, I don't believe it will work--someone has already tried it. The DRL's in our cars are not wired for those to work correctly.
Thanks Cubby 558 - I sure do wish GM had been more uniform with the lighting system!
