I feel like I am missing something and hope this is an easy answer that I am just not seeing.
How do we get our cars into a key on engine off state?
I am looking to reprogram some TPMS sensors.
Hummm, I am going to assume the 2009 is different then, as it is obvious. On my car there is a fair sized rectangular button, the big circle at the top is for starting, there are two small spots on the bottom, the one on the left for shutting down and the one on the right side is marked 'ACC' for accessory mode.
GrayToad, that is the same. You may want to re-read the question. I am wanting the ignition on without the engine running. BTW, it doesn't really matter what side of the switch bottom you press. What matters is the existing condition. If the ignition is on (engine running) a switch bottom press turns everything off. If everything is off a switch bottom press puts the car in accessory mode. If everything is off a switch bottom press and hold turns on the ignition/car but does not start the engine.
Oh, so you mean if you want to access info on the driver info centre that does not work on accessory etc? That is darn handy info as I have started my car more than once to find out something: Thanks! It never occured to me that that was available(blonde too!)
