Installing Spark Plug and Coils 2006 XLR/V
Crumpler
St Louis
2006 XLR/V
Just a few observations on a deferred maintenance job. For those down the road.
Many helpful threads on plug and coil specs here on the forum
Remember the 4.4L likes 0.040 gaps on the spark plugs. Some parts stores will pull up specs on the 4.6L and sell you 0.050 plugs. Ask me how I know.
The interweb opposes manual gapping on Iridium FWIW. Done carefully, I don’t see a big issue there.
I replaced the coil packs at the same time. Be prepared for some monetary sticker shock. The stock coils are mounted on modular plate, obviously four per side.
Others can educate me but I did not find enough clearance to remove the coil packs without pulling the intake manifold.
The only curve ball here is on the drivers side, be prepared to disconnect the fuel supply line.
Unless you are prepared, there’s another trip to the store for GM’s fuel line release tool. I believe I used the 3/8 (9.5mm).
Tool use requires a little technique. I found pushing the fitting forward, instead of pulling, while pressing tool into gap was key.
There is also what I’m calling a low pressure fuel return line in the lower corner by the fire wall that I needed to disconnect for room as well. This one has more conventional tab lock.
Other then the above, it’s like any other car ;)
Others with more knowledge feel free to add or subtract to my findings
Dave H.
just a heads up for next time - you can remove the coil packs indvitually - they don't have to come out 4 at a time. that single torx screw will allow a single coilpack to come out.
the indiviutal packs are used on many GM cars - they are only expensive as an entire northstar assembly.
food for thought for next time.
Good to know Rich.
That would eliminate a lot of the tear down that I described above.
I tend to be a parts cannon sometimes.
I saw a blurb somewhere that they had changed the coil plug connector at some point in the production run. I don’t know if that is accurate or not.
to be fair - I am also a parts cannon at times too - sometimes I feel like i prefer the wrenchiing part over the research part - lol
Related - I had changed one coil pack at one point due to misfires... and then 6 months later another one failed... and then 3 months later another failed after that - so probalby would have been better to swap them all out at once, but I Was trying to be more surgical about it and ended up spending more time later trying to do the "right thing" - oh well
Yes! The research. Only rivaled by the “parts waiting” game. Two of my less then favorite pastimes.
Best.
Dave
There are plenty of good colls that will work without buyng the expensive 4 pack. and you dont need to pull the supercharger.
I'm also having a slight misfire. I mostly buy GM Genuine Parts, but just one coil is nearly $100. Has anyone had success with a cheaper option? Also, according to another post, there are differences in the connectors from the older and newer coils. Any advice here? I'm good to grind down a plastic tab, if needed.
I paid about 235.00 per side FWIW.
PS: I didn’t touch the supercharger:)
But, I intend on doing a full top end refresh at some point. How the hell do you get to stuff like the throttle body and coolant sensor? Looks hairy back there.
They dont interchange. You can take the gm part number and cross it. There are aftermarket coils for 22-30 that are higher output than factory. We've come a long way on that type thing over stock gm
Other than valve cover gaskets, leave it alone. Not much of anything needs attention on the top end.
Torque Shop
