P0604 issue
Descyphal
Florida
2009 Black Platinum
I’m looking for some advice on my dad’s 2009 Cadillac XLR Platinum, which has just over 17,000 miles.
My dad and I attended a car show this past weekend. As we were leaving, his XLR suddenly shut off. We cycled the ignition several times, but initially got no response. After a few attempts, “Low Power Mode” appeared on the display.
We hooked up jumper cables and kept trying to start it. After about 15 minutes, it started but immediately shut off again.
We had the car brought to my shop, where we scanned it and found code P0604—Control Module Random Access Memory (RAM) Error. Based on what we’ve found so far, we suspect the module may have failed, but I’d like to explore other possibilities before replacing it.
Has anyone experienced this with a 2009 XLR? What ended up fixing it? Is there a reset, reprogramming, or relearn procedure that might resolve the issue?
If the module needs to be replaced, can anyone recommend a reliable source for a used or rebuilt unit, or does anyone have one available?
Any advice or firsthand experience would be appreciated. Thanks in advance!
Id say start with the battery. You did not run it long enough to charge. It almost wont charge a cead battery with everything working. It needs to be put on a charger. Also dont jump it. Pull the post, charge the battery. spikes can damage modules and the car does not like to be jumped
Update: fresh battery after sitting 24 hours disconnected. Grounds and power cables checked. CEL immediately back on after reconnected, power and grounds to modules verified
Torque Shop
