beyerch
- Joined
- Jun 2, 2025
- Messages
- 25
- Location
- chicago
- My XLR/V(s)
- 2006 XLR/V, 2007 XLR, looking for 04/05 XLR for Product Testing
Thought I would make a post here as I have been primarily discussing on FB forums what I've been up to.
About a year ago, I bought a "project" 2006 XLR-V & boy did it deliver.
One of the (known) problems was the top. You all have heard the story probably about a thousand times, water in trunk, pump/module(s) wrecked, yada, yada, yada. Well, I (admittedly) didn't do my research and had no idea how rare the parts were going to be. While I did end up buying a used module, the prices being charged (over $1500 on eBay right now) really irked me. Since I have a background in all the relevant areas & was in need of some projects, I decided to take on the task of making replacements.
While my goal was to have something worked about at the end of last year, work and other stuff have delayed that progress; however, happy to report that the first replacement module has been bench & in-vehicle tested successfully. Now that I have the first board tested, I'll be finishing up a batch of ~15 in the next week or so. (while I ordered them assembled from production factory, there was a mistake and I have to fix a couple minor things manually until I get the next batch)
Some things of note:
1 - I did not reproduce the black enclosure - thought is that people use the one they already have or I will get extras from bad units.
2 - The white connector on the board is almost impossible to get. I found one supplier, but they want me to buy 1,000..... Because of this I'll either re-use ones from the bad boards I have / get or may swap with similar connectors. Regardless of the route, it will be 100% plug and play. *NO* modification to existing wiring.
3 - In regards to points 1 & 2, if you had bad module(s), I'd be interested in buying for those pieces. (buy outright or core exchange for replacement unit)
4 - Price - Honestly, I not 100% firm. Will definitely be 50%+ below current eBay prices for old/used modules. First couple people could be even cheaper in exchange for being 'beta testers'. Long term goal when I get the PCBA issue resolved s/b < $500
Other items of note:
1 - Currently working on new firmware for *ALL* units. Phase 1 was getting hardware, Phase 2 is to make life easier as the current firmware is really lacking, especially for diagnostics.
2 - Top Diagnostic software (mobile/PC) Bundling all the pain and suffering I've went through researching these things to make a guided workflow type troubleshooter that will utilize data from module + user input to help simplify diagnosis.
Some video of replacement module operating my top. (it's a bit slow as I was low on fluid, my fault for not checking it before filming)
youtube.com
Cadillac XLR Replacement Folding Top Module (FTC) Demo
Demonstration / Proof of successfully operating replacement Folding Top Module.
