JWILLIS
New member. Ten year owner of a 2007 black with beige interior. We recently bought a keyfob to replace a lost one several years back. We had the dealer program the new fob and all appeared fine until trying to place groceries in the trunk later that afternoon. Trunk will not open with either keyfob nor the dash button. You can open the trunk with the key in the rear bumper and it will close with the trunk lid mounted button. Another weird quirk, if you pop the trunk with the key, you can then operate the trunk up and down with either keyfob as long as you don’t allow the lid to go fully open or closed. The keyfob will not open or close the lid from a resting position. They will operate the lid up and down if you keep the lid from completing its cycle. Took it back to the dealer because it would appear to be a programming problem since it happened right after having the keyfob programmed. They don’t have a clue. They checked the fuses, which I had already done, then basically threw their hands up and said we don’t know. Any help would be greatly appreciated. Thanks.
