steve05
Hi gang,
has anybody figured out a way to prevent trunk water leaks. i have had mine at dealers several times but no luck, i have studies the seals closely and all are in good shape. put bluing on trunk lid to confirm good contact, 100% all around? best i can figure out is where the seals merge at the passenger side door jam. any thoughts. By the way for those who dont know you should cut the drain tube in your hydraulic top motor area to prevent water from filling the compartment.
