GizmoQ
- Joined
- Jun 3, 2010
- Messages
- 1,079
- Location
- Traveling the Country
- My XLR/V(s)
- 2006 Black Raven XLR-V; 1996 Eldorado ESC-V
Since I finally got my Z06 wheels, I figured I better start researching adding TPMS sensor that work with the car's internal warning system. Started by searching this site and others for part numbers and only came up with the OEM part #25753868. However, it seems to have been replaced by part #25758220.
The OEM sensors look to be the Dorman 974-012 models, but for those of us with aftermarket wheels another manufacturer has stems that tilt. This second company, Oro-Tek, has product OSC-0076 that are "OEM Compatible." None of these sensors are cheap, but I did find the Dormans at Rock Auto for $46.79 each. Interestingly, Rock auto also shows two other brands as compatible, but only the Dorman comes w/Low Tire Pressure Monitoring System (UJ6). (The UJ6 is important for our cars)
As a side note, I was amazed at the vehicles that use the same Dorman sensors:
2004-2008 Base XLR
2008-2009 Platinum Base XLR
2006-2009 XLR-V
2005-2008 Base STS
2008 Platinum STS
2006-2008 STS-V
2005-2009 Base Corvette
2006-2009 Corvette Z06
2008 Corvette 427 Limited Edition Z06
2009 Corvette ZR1
Another interesting find was the programming instructions from Dorman. They list two procedures for programming the sensors: the Special Tool J-46079 i.e., "big hunking magnet" method and increase/decrease pressure method. Once I get mine mounted with wheels and tires, I'll continue here with the results of the learning procedure.
2004-2008 Base XLR
2006-2009 XLR-V
2005-2008 Base STS
2008 Platinum STS
2006-2008 STS-V
2009 Corvette ZR1
