2004 - 2009 Cadillac XLR: Service Bulletin: #01-07-30-032E: Transmission Oil Leaking From Transmission Vent
#01-07-30-032E: Transmission Oil Leaking From Transmission Vent (Replace Transmission Case Cover (Channel Plate) Gasket) - (Sep 29, 2008)
Subject Transmission Oil Leaking From Transmission Vent (Replace Transmission Case Cover (Channel Plate) Gasket)
Models 1997-2009 GM Passenger Cars and Light Duty Trucks (including Saturn)
with Hydra-Matic 4T65-E Automatic Transmission (RPOs MN3, MN7, M15, M76)
This bulletin is being revised to add the 2008 and 2009 model years. Please discard Corporate Bulletin Number #01-07-30-032D (Section 07 – Transmission/Transaxle).
Some customers may comment on a transmission oil leak.
This condition may be caused by an improperly torqued channel plate gasket.
To correct this condition, replace the case cover (channel plate) gaskets (429 and 430). Refer to Unit Repair publication in SI of the appropriate vehicle being serviced.
Visual inspection of the upper gasket (1) will reveal damage at the referenced area.
Part Number
Description
Qty
24206391
Gasket Kit, A/Trns Case Cvr
1
Posted by: Rob Loszewski - January 7, 2020. This article has been viewed 542 times.
Online URL: https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-01-07-30-032e-transmission-oil-leaking-from-transmission-vent-129.html
