2009 Cadillac XLR: Service Bulletin: #PIC4930: Audible Click Noise When turning The Steering Wheel Left Or Right
#PIC4930: Audible Click Noise When turning The Steering Wheel Left Or Right - keywords angle column left position right sensor stability steering SWPS wheel - (Jul 18, 2008)
Subject Audible Click Noise When Turning the Steering Wheel Left or Right
Models 2009 Cadillac XLR
2009 Chevrolet Corvette
Some customers may comment of a click noise from the steering column when turning the steering wheel left or right. This will typically occur when the vehicle is not moving and the steering wheel is turned either left or right. This may be caused by the Steering Wheel Position Sensor (SWPS) not being installed correctly on the steering column.
  1. Remove the close out panel just below the steering column.
    20009 Cadillac XLR - #PIC4930: Audible Click Noise When turning The Steering Wheel Left Or Right
  2. Refer to the image above. Inspect the vehicle to be sure the Steering Wheel Position Sensor (SWPS) is installed correctly. In call out number 1 above, the SWPS is not installed correctly. Note: the SWPS has a tab that should rest in the opening as called out in number 2 above. In call out number 2 above, the SWPS is installed correctly. Note: The tab of the SWPS is secured in the opening. If the sensor is found to be installed incorrectly, remove or rotate the sensor so that it is installed correctly as shown in call out number 2 above.
Posted by: Rob Loszewski - January 8, 2020. This article has been viewed 657 times.
Online URL: https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-pic4930-audible-click-noise-when-turning-the-steering-wheel-left-or-right-140.html
