2004 - 2009 Cadillac XLR and XLR-V: Service Bulletin: #PIC4135B: Retractable Roof Will Not Fully Stow Into The Rear Compartment
#PIC4135B: Retractable Roof Will Not Fully Stow Into The Rear Compartment - keywords folding gas hydraulic inoperative latch loose rod strut - (Nov 10, 2008)
Subject Retractable Roof Will Not Fully Stow Into The Rear Compartment
Models 2004 - 2009 Cadillac XLR and XLR-V
This PI was superseded to update model years. Please discard PIC4135A.
A customer may have a concern where the folding top will not retract or stow into the rear compartment. This may be the cause of a bent folding top gas strut(s). These are the struts that are parallel to the ground and reside on the left and right side of the trunk area connected to the hinge or linkage and are behind the trim between the wheel well and the B-pillar. These are NOT the gas struts that support the deck lid when the deck lid is open.
If the folding top is retracted into the trunk but seems to be inches away from the retracted position, press down on the top roof panel. If it feels springy, a bent gas strut rod may be at fault. Remove the gas struts for the folding top (not the deck lid) and inspect. If the strut(s) are found to be bent replace strut(s) that are bent and re-evaluate the top operation.
Posted by: Rob Loszewski - January 10, 2020. This article has been viewed 784 times.
Online URL: https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-and-xlr-v-service-bulletin-pic4135b-retractable-roof-will-not-fully-stow-into-the-rear-compartment-157.html
