2004 - 2009 Cadillac XLR: Service Bulletin: #PIC3998B: Flash To Pass Inoperative With Headlamps Off
#PIC3998B: Flash To Pass Inoperative With Headlamps Off - keywords beam dimmer discharge head headlight HID high highbeam intensity lamp light low switch - (Nov 11, 2008)
Subject Flash To Pass Inoperative With Headlamps Off
2006 - 2009 Cadillac DTS
This PI was superseded to update model years. Please discard PIC3998A.
The Cadillac XLR and DTS use a single High Intensity Discharge (HID) lamp on each side of the vehicle. These lamps perform both high and low beam headlamp functions through the use of a plate built into the lamp. This plate partially covers the lamp during low beam operation and fully retracts during high beam operation.
When first turned on, HID Headlamps may take a few seconds to reach full intensity. As a result, the flash to pass feature does not operate unless the headlamps are already illuminated.
This is a normal characteristic. No repair attempts should be made.
Posted by: Rob Loszewski - January 10, 2020. This article has been viewed 2186 times.
Online URL: https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic3998b-flash-to-pass-inoperative-with-headlamps-off-158.html
