2006 Cadillac XLR: Service Information: High Mount Stop Lamp Replacement |
Document ID: 1109348 The high mount stop lamp is illuminated by a Light Emitting Diode (LED). The lamp and diode are serviced as an complete assembly. Open the rear compartment. Installation Procedure Important: Ensure the rubber grommet (1) attached to the stop lamp wiring harness is properly installed and sealed, in order to avoid water intrusion into the rear compartment and chafing of the wiring harness. Position the stop lamp (3) to the rear compartment lid. Notice: Refer to Fastener Notice in the Preface section. Install the stop lamp bolts. General Motors bulletins are intended for use by professional technicians, not a "do-it-yourselfer". They are written to inform those technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions and know-how to do a job properly and safely. If a condition is described, do not assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See a General Motors dealer servicing your brand of General Motors vehicle for information on whether your vehicle may benefit from the information. © Copyright General Motors Corporation. All Rights Reserve |
Posted by: Rob Loszewski - December 20, 2016. This article has been viewed 3668 times. |
Online URL: https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-service-information-high-mount-stop-lamp-replacement-58.html |
