2004 - 2009 Cadillac XLR: Service Bulletin: Diagnostic Tip - Difficulty Programming Modules, Cannot Achieve Ignition On, Engine Off Mode
#PIC3520C: Diagnostic Tip - Difficulty Programming Modules, Cannot Achieve Ignition On, Engine Off Mode - (Nov 2, 2015)
Subject: Diagnostic Tip - Difficulty Programming Modules, Cannot Achieve Ignition On, Engine Off Mode
Models: 2005 - 2011 Cadillac STS
This PI was superseded to update Model Years. Please discard PIC3520B.
Some technicians may experience failed module programming or difficulty performing certain diagnostic procedures due to the ignition not being in the "Ignition On, Engine Off" mode. The vehicles listed in this PI use a keyless access system with push button start.
To reach the "Ignition On, Engine Off" mode, press and hold the ACC/OFF portion of the Start/ACC/OFF mode button for 5 seconds with a valid keyless entry transmitter inside the vehicle and the transmission in Park (Auto Trans) or Neutral (Man Trans).
Posted by: Rob Loszewski - December 18, 2016. This article has been viewed 3584 times.
Online URL: https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-diagnostic-tip-difficulty-programming-modules-cannot-achieve-ignition-on-engine-off-mode-6.html
