2004 - 2008 Cadillac XLR: Service Bulletin: Stabilitrak/Active Handling Light On, Service Stabilitrak/Active Handling Message on DIC |
Subject: Stabilitrak/Active Handling Light On, Service Stabilitrak/Active Handling Message on DIC, DTC C0710 Steering Wheel Position Sensor (SWPS) Signal Set (Install Clip in SWPS Connector) #06-02-35-002B - (10/19/2007) Models: Condition Diagnosis with a scan tool may reveal a DTC C0710. Cause Correction Install the clip (1), P/N 19179794, into the connector. This clip will act as a terminal positive assurance (TPA) and prevent any movement of the terminals. General Motors bulletins are intended for use by professional technicians, not a "do-it-yourselfer". They are written to inform those technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions and know-how to do a job properly and safely. If a condition is described, do not assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See a General Motors dealer servicing your brand of General Motors vehicle for information on whether your vehicle may benefit from the information. © Copyright General Motors Corporation. All Rights Reserve |
Posted by: Rob Loszewski - December 25, 2016. This article has been viewed 7077 times. |
Online URL: https://www.xlr-net.com/knowledgebase/article/2004-2008-cadillac-xlr-service-bulletin-stabilitrak-active-handling-light-on-service-stabilitrak-active-handling-message-on-dic-89.html |
