<title>Home - All Categories - Brakes  </title>
<link>https://www.xlr-net.com/knowledgebase/category/brakes/3/</link>
<description>This RSS Feed contains Articles of Category in the knowledge base. You can click on the title to view its content. Powered by PHPKB (https://www.phpkb.com)</description>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-recall-04086-rear-brake-lining-routing-101.html</guid>
										<title>2004 - 2005 Cadillac XLR: Recall: 04086 -- Rear Brake Lining Routing</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-recall-04086-rear-brake-lining-routing-101.html</link>
										<description><![CDATA[Recall #: 04086 Date:&nbsp;n/a Subject:&nbsp; 04086 -- Rear Brake Lining Routing Model(s): 2004 - 2005 Cadillac, XLR, 2005 Chevrolet Corvette Condition General Motors has decided that a defect, which relates to motor vehicle safety, exists in certain...]]></description>
										<description><![CDATA[Source: GM Techlink Date: October 2010 Subject:&nbsp;&nbsp;Electronic Brake Control Module Communication Models: 2009 Cadillac XLR On some 2008-2011 Enclave; 2007-2011 Escalade, Escalade ESV, Escalade EXT, Avalanche, Silverado, Suburban, Tahoe,...]]></description>
										<description><![CDATA[#08-05-22-007A: Click Type Noise Heard from Passenger Side Floor (Foot) Area When Brake Pedal is Pressed (Inspect Stop Lamp Relay and Replace, if Necessary) - (Feb 23, 2011)    Subject:&nbsp; Click Type Noise Heard from Passenger Side Floor (Foot)...]]></description>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-v-service-information-cross-drilled-rotors-66.html</guid>
										<title>2006 Cadillac XLR-V: Service Information: Cross Drilled Rotors</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-v-service-information-cross-drilled-rotors-66.html</link>
										<description><![CDATA[Cross-drilled brake rotors (fig. 16 -attached) are being used on the 2005 1/2 Pontiac Grand Prix GXP, and available on the 2005 Chevrolet C6 Corvette and the upcoming Cadillac XLR-V.  If required, these brake rotors can be machined on a lathe in a...]]></description>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-service-bulletin-information-on-visual-brake-rotor-surface-cracking-3.html</guid>
										<title>2005 - 2009 Cadillac XLR: Service Bulletin:  Information on Visual Brake Rotor Surface Cracking</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-service-bulletin-information-on-visual-brake-rotor-surface-cracking-3.html</link>
										<description><![CDATA[#05-05-23-007B: Information on Visual Brake Rotor Surface Cracking - (Apr 15, 2014)    Subject: Information on Visual Brake Rotor Surface Cracking   Models: 2005 - 2009 Cadillac XLR   2005 - 2013 Chevrolet Corvette   with Heavy Duty Brakes &ndash;...]]></description>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-bulletin-starts-w-o-brake-input-and-hard-to-shift-out-of-park-14.html</guid>
										<title>2004 - 2005 Cadillac XLR: Service Bulletin: Starts w/o Brake Input and Hard to Shift out of Park</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-bulletin-starts-w-o-brake-input-and-hard-to-shift-out-of-park-14.html</link>
										<description><![CDATA[#PIC3079: 04-05 Cadillac XLR and 05 Chevrolet Corvette Starts w/o Brake Input and Hard to Shift out of Park, DTC C0161 - ABS brake BTSI switch code DTC key keyless park pedal remote RKE start - (Aug 4, 2004)    Subject:&nbsp;  2004 - 2005 Cadillac...]]></description>
