<title>Home - All Categories - Chassis and Suspension  </title>
<link>https://www.xlr-net.com/knowledgebase/category/chassis-and-suspension/4/</link>
<description>This RSS Feed contains Articles of Category in the knowledge base. You can click on the title to view its content. Powered by PHPKB (https://www.phpkb.com)</description>
										<guid>https://www.xlr-net.com/knowledgebase/article/march-17-2003-2004-cadillac-xlr-advanced-structure-and-chassis-create-remarkable-blend-of-luxury-and-performance-34.html</guid>
										<title>March 17, 2003:  2004 Cadillac XLR - Advanced Structure and Chassis Create Remarkable Blend of Luxury and Performance</title>
										<link>https://www.xlr-net.com/knowledgebase/article/march-17-2003-2004-cadillac-xlr-advanced-structure-and-chassis-create-remarkable-blend-of-luxury-and-performance-34.html</link>
										<description><![CDATA[FOR RELEASE: March 17, 2003 CONTACT(S): Jeff Kuhlman, Cadillac Communications Kelly Cusinato, Cadillac Communications David Caldwell, GM Product Communications Cadillac XLR - Advanced Structure and Chassis Create Remarkable Blend of Luxury and...]]></description>
										<description><![CDATA[#PIT4162H: Service Stability Lamp DTC C0131 - (Jun 17, 2011)    Subject:&nbsp; Service Stability Lamp DTC C0131 &nbsp;   Models:&nbsp; 2008-2011 Buick Enclave   2007-2011 Cadillac Escalade, ESV, EXT   2009 Cadillac XLR   2007-2011 Chevrolet Avalanche...]]></description>
										<description><![CDATA[#PIC4930: Audible Click Noise When turning The Steering Wheel Left Or Right - keywords angle column left position right sensor stability steering SWPS wheel - (Jul 18, 2008)    Subject:&nbsp; Audible Click Noise When Turning the Steering Wheel Left...]]></description>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-cadillac-xlr-techlink-article-drive-axle-boot-pliers-64.html</guid>
										<title>2005 Cadillac XLR:  TechLink Article: Drive Axle Boot Pliers</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-cadillac-xlr-techlink-article-drive-axle-boot-pliers-64.html</link>
										<description><![CDATA[New drive axle boot pliers (fig. 6) CH-48894 have been released for these vehicles:  2005 Cadillac XLR 2005-08 Corvette, Equinox, Impala, Monte Carlo, Grand Prix, Torrent 2006-08 HHR, Hummer H3 2007 Acadia, Outlook, VUE, Rainier, Enclave 2008 VUE...]]></description>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-service-bulletin-07-04-95-001a-tapping-or-scraping-noise-from-rear-wheel-area-replace-wheel-drive-shaft-nut-may-29-2008-127.html</guid>
										<title>2005 - 2009 Cadillac XLR: Service Bulletin: #07-04-95-001A: Tapping or Scraping Noise From Rear Wheel Area (Replace Wheel Drive Shaft Nut) - (May 29, 2008)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-service-bulletin-07-04-95-001a-tapping-or-scraping-noise-from-rear-wheel-area-replace-wheel-drive-shaft-nut-may-29-2008-127.html</link>
										<description><![CDATA[#07-04-95-001A: Tapping or Scraping Noise From Rear Wheel Area (Replace Wheel Drive Shaft Nut) - (May 29, 2008) Subject: &nbsp;&nbsp;&nbsp; &nbsp;Tapping or Scraping Noise From Rear Wheel Area (Replace Wheel Drive Shaft Nut)&nbsp;&nbsp; &nbsp;Models:...]]></description>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-service-bulletin-tapping-or-scraping-noise-from-rear-wheel-area-68.html</guid>
										<title>2005 - 2009 Cadillac XLR:  Service Bulletin:  Tapping or Scraping Noise From Rear Wheel Area</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-service-bulletin-tapping-or-scraping-noise-from-rear-wheel-area-68.html</link>
										<description><![CDATA[Subject: Tapping or Scraping Noise From Rear Wheel Area (Replace Wheel Drive Shaft Nut) Models: 2005-2009 Cadillac XLR 2005-2009 Chevrolet Corvette  This bulletin is being revised to add the 2009 model year. Please discard Corporate Bulletin Number...]]></description>
										<description><![CDATA[Drivetrain - Rear Differential Fluid Leak  Bulletin No.: 03-04-20-006 Date: November 18, 2003 TECHNICAL Subject: Fluid Leak at Rear Axle (Replace Left Differential Side Cover 0-Ring and Left Axle Shaft Seal, Add Sealant to Side Cover Flange) Models:...]]></description>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-recall-notice-lower-control-arm-ball-stud-washer-75.html</guid>
										<title>2004 Cadillac XLR: Recall Notice: Lower Control Arm Ball Stud Washer</title>
										<description><![CDATA[Recall Bulletin 04043 &ndash; Lower Control Arm Ball Stud Washer Date: August 2004 Subject: 04043 &ndash; Lower Control Arm Ball Stud Washer Models: 2004 Cadillac CTS, SRX and XLR 2004 Chevrolet Corvette CONDITION General Motors has decided that a...]]></description>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic5335a-composite-transverse-spring-damage-dec-13-2012-112.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #PIC5335A: Composite Transverse Spring Damage - (Dec 13, 2012)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic5335a-composite-transverse-spring-damage-dec-13-2012-112.html</link>
										<description><![CDATA[#PIC5335A: Composite Transverse Spring Damage - (Dec 13, 2012)    Subject:&nbsp; Composite Transverse Spring Damage   Models:&nbsp; 2004 - 2009 Cadillac XLR   1997 - 2013 Chevrolet Corvette     This PI was superseded to update model years and...]]></description>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-rear-swaybar-parts-listing-80.html</guid>
										<title>2004 - 2009 Cadillac XLR: Rear Swaybar Parts Listing</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-rear-swaybar-parts-listing-80.html</link>
										<description><![CDATA[Below is a listing of 2004 - 2009 Cadillac XLR rear swaybar part numbers: Part # - Name - (Number) 15806422 - shaft/swaybar 11516078 -&nbsp; nut - (4) 15907003 -&nbsp; link - (2) 11515775 -&nbsp; bolt - (2) 10317560 - insulator - (2) 15142776 -&nbsp;...]]></description>
										<description><![CDATA[#PI0430C: Magnaride Magnetically Controlled Suspension Electrical Connector Not Seated, Service Suspension System Message, DTCs C0575, C0580, C0585 or C0590 - (June 20, 2019)    Subject: Magnaride&trade; Magnetically Controlled Suspension Electrical...]]></description>
										<description><![CDATA[Subject: Stabilitrak/Active Handling Light On, Service Stabilitrak/Active Handling Message on DIC, DTC C0710 Steering Wheel Position Sensor (SWPS) Signal Set (Install Clip in SWPS Connector) #06-02-35-002B - (10/19/2007) Models: 2004 - 2008 Cadillac...]]></description>
										<description><![CDATA[Subject: Rear Axle Clunk and/or Chatter Type Noise on Turns (Drain/Refill Rear Differential Fluid) #07-04-20-002A - (01/09/2008) Models: 2004 - 2008 Cadillac XLR (Including V-Series and Export) 2005 - 2008 Chevrolet Corvette (Including Z06 and Export...]]></description>
										<description><![CDATA[Service Bulletin #:&nbsp; 06-02-35-002 Date:&nbsp;January 2006 Subject:&nbsp; Diagnostic Trouble Code (DTC) C0710 Steering Wheel Position Sensor (SWPS) Signal, Service Stability System Message on Driver Information Center (DIC) (Inspect and Secure...]]></description>
