<title>Home - All Categories - Engine and Drivetrain  </title>
<link>https://www.xlr-net.com/knowledgebase/category/engine-and-drivetrain/6/</link>
<description>This RSS Feed contains Articles of Category in the knowledge base. You can click on the title to view its content. Powered by PHPKB (https://www.phpkb.com)</description>
										<guid>https://www.xlr-net.com/knowledgebase/article/september-5-2002-gm-s-livonia-engine-plant-committed-to-quality-83.html</guid>
										<title>September 5, 2002:  GM`s Livonia Engine Plant Committed to Quality</title>
										<link>https://www.xlr-net.com/knowledgebase/article/september-5-2002-gm-s-livonia-engine-plant-committed-to-quality-83.html</link>
										<description><![CDATA[FOR RELEASE: September 5, 2002 CONTACT(S): Thomas Read, GM Powertrain Communications Dave Roman, GM Powertrain Communications GM's Livonia Engine Plant Committed to Quality  Next-Generation Northstar V8 to Benefit From New Manufacturing Equipment and...]]></description>
										<description><![CDATA[FOR RELEASE: September 5, 2002 CONTACT(S): Thomas Read, GM Powertrain Communications Dave Roman, GM Powertrain Communications GM Powertrain's 2004 Northstar V8 Sets New Standard  Cadillac XLR and SRX to Benefit from Next-Generation Northstar...]]></description>
										<description><![CDATA[FOR RELEASE: March 17, 2003 CONTACT(S): Jeff Kuhlman, Cadillac Communications Kelly Cusinato, Cadillac Communications David Caldwell, GM Product Communications Next-Generation Northstar Sets New Standard in Performance and Refinement For Cadillac XLR...]]></description>
										<description><![CDATA[#PIC4930: Audible Click Noise When turning The Steering Wheel Left Or Right - keywords angle column left position right sensor stability steering SWPS wheel - (Jul 18, 2008)    Subject:&nbsp; Audible Click Noise When Turning the Steering Wheel Left...]]></description>
										<description><![CDATA[Special Coverage Adjustment 15682 Primary Tank Module Flange Fuel and Vapor Leaks Reference Number: N150682 Release Date: August 2016 GWM Number: 2015682 Revision: 01 Revision Description: This bulletin is being revised to accurately depict the...]]></description>
										<description><![CDATA[#PIP4577M: SES Light With DTCs P0171 And P0174 - Possible Air Leaks - (Jul 5, 2012)    Subject:&nbsp; SES Light With DTCs P0171 And P0174 - Possible Air Leaks &nbsp;   Models:&nbsp; 2007 - 2009 Cadillac SRX, STS, XLR   With 4.6L Engine (RPO Code LH2)...]]></description>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-v-techlink-article-supercharging-explained-62.html</guid>
										<title>2006 - 2009 Cadillac XLR-V: TechLink Article: Supercharging Explained</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-v-techlink-article-supercharging-explained-62.html</link>
										<description><![CDATA[Devices for delivering air into an engine at pressures higher than atmospheric fall into two major groups -- mechanically driven (superchargers) and exhaust gas driven (turbochargers). GM's supercharged engines have historically incorporated the...]]></description>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-v-service-bulletin-pip4493-ses-light-due-to-dtcs-p0171-and-or-p0174-inspect-air-cleaner-outlet-duct-and-supercharger-inlet-duct-clamps-152.html</guid>
										<title>2006 - 2009 Cadillac XLR-V: Service Bulletin: #PIP4493: SES Light due to DTCs P0171 and/or P0174 - Inspect Air Cleaner Outlet Duct and Supercharger Inlet Duct Clamps</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-v-service-bulletin-pip4493-ses-light-due-to-dtcs-p0171-and-or-p0174-inspect-air-cleaner-outlet-duct-and-supercharger-inlet-duct-clamps-152.html</link>
										<description><![CDATA[#PIP4493: SES Light due to DTCs P0171 and/or P0174 - Inspect Air Cleaner Outlet Duct and Supercharger Inlet Duct Clamps - (Oct 3, 2008)    Subject:&nbsp; SES Light due to DTCs P0171 and/or P0174 - Inspect Air Cleaner Outlet Duct and Supercharger...]]></description>
										<description><![CDATA[#08-06-04-038: LC3 4.4L Supercharged Engine Hard Start, Miss, Misfire, Idle Rough, MIL/SES Light, DTCs P0300/P0301/P0302/P0303/P0304/P0305/P0306/P0307 or P0308 Due to Fuel Fouled Spark Plugs (Replace Spark Plugs) - (Jul 16, 2008)    Subject: LC3 4.4L...]]></description>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-pip4112q-normal-characteristic-sag-or-hesitation-on-acceleration-9.html</guid>
										<title>2006 - 2009 Cadillac XLR XLR-V: Service Bulletin: #PIP4112Q: Normal Characteristic - Sag Or Hesitation On Acceleration</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-pip4112q-normal-characteristic-sag-or-hesitation-on-acceleration-9.html</link>
										<description><![CDATA[#PIP4112Q: Normal Characteristic - Sag Or Hesitation On Acceleration - (Sep 16, 2015)    Subject: Normal Characteristic - Sag Or Hesitation On Acceleration   Models: 2008-2012 Buick Enclave   2010-2011 Buick LaCrosse MH7   2010-2013 Buick LaCrosse...]]></description>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-and-xlr-v-service-bulletin-pic4050a-whine-noise-from-power-steering-at-cold-start-138.html</guid>
										<title>2006 - 2009 Cadillac XLR and XLR-V: Service Bulletin: #PIC4050A: Whine Noise from Power Steering at Cold Start</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-and-xlr-v-service-bulletin-pic4050a-whine-noise-from-power-steering-at-cold-start-138.html</link>
										<description><![CDATA[#PIC4050A: Whine Noise from Power Steering at Cold Start - keywords air foam growl left right steer wheel - (Jun 27, 2008)    Subject:&nbsp; Whine Noise from Power Steering at Cold Start &nbsp;   Models:&nbsp; 2006 - 2009 Cadillac XLR and XLR-V    ...]]></description>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-pip4112r-normal-characteristic-sag-or-hesitation-on-acceleration-mar-24-2017-123.html</guid>
										<title>2006 - 2009 Cadillac XLR - XLR-V: Service Bulletin: #PIP4112R: Normal Characteristic - Sag Or Hesitation On Acceleration - (Mar 24, 2017)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-pip4112r-normal-characteristic-sag-or-hesitation-on-acceleration-mar-24-2017-123.html</link>
										<description><![CDATA[#PIP4112R: Normal Characteristic - Sag Or Hesitation On Acceleration - (Mar 24, 2017)    Subject:&nbsp; Normal Characteristic - Sag Or Hesitation On Acceleration        Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:   from  to  from  to   ...]]></description>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-service-information-fuel-tank-system-73.html</guid>
										<title>2004 Cadillac XLR: Service Information: Fuel Tank System</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-service-information-fuel-tank-system-73.html</link>
										<description><![CDATA[Corvette and Cadillac XLR Partway through model year 2003, a new fuel tank system was introduced on the Corvette (fig. 1). This system continues with slight differences in the 2004 Corvette and Cadillac XLR.   TIP: For 2003 Corvettes only, this...]]></description>
										<description><![CDATA[Drivetrain - Rear Differential Fluid Leak  Bulletin No.: 03-04-20-006 Date: November 18, 2003 TECHNICAL Subject: Fluid Leak at Rear Axle (Replace Left Differential Side Cover 0-Ring and Left Axle Shaft Seal, Add Sealant to Side Cover Flange) Models:...]]></description>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-service-bulletin-pi01243-extended-crank-time-4-6-ignition-pcm-performance-start-starter-switch-jul-23-2003-116.html</guid>
										<title>2004 Cadillac XLR:  Service Bulletin:  #PI01243: Extended Crank Time - 4.6 ignition PCM performance start starter switch - (Jul 23, 2003)</title>
										<description><![CDATA[#PI01243: Extended Crank Time - 4.6 ignition PCM performance start starter switch - (Jul 23, 2003)    Subject:&nbsp; Extended Crank Time   Models:&nbsp; .(04 Cadillac SRX w/RPO LH2)   &nbsp; &nbsp;(04 Cadillac XLR w/RPOLH2)    When servicing the...]]></description>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-recall-special-coverage-adjustment-fuel-tank-quick-connector-leak-77.html</guid>
										<title>2004 Cadillac XLR:  Recall: Special Coverage Adjustment - Fuel Tank Quick Connector Leak</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-recall-special-coverage-adjustment-fuel-tank-quick-connector-leak-77.html</link>
										<description><![CDATA[Some 2004 model year Cadillac XLR&nbsp; and Chevrolet Corvette vehicles may have a fuel tank leak at the quick connectors that are used to link the left and right fuel tanks.&nbsp; The customer may notice a fuel odor while the vehicle is being...]]></description>
										<description><![CDATA[#PIP4925A: SES Light with Fuel Trim and or Oxygen Sensor Codes - (Mar 21, 2017)    Subject:&nbsp; SES Light with Fuel Trim and or Oxygen Sensor Codes        Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:   from  to  from  to      All   All...]]></description>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-and-xlr-v-service-bulletin-pip4245a-torque-tube-fully-serviceable-jun-20-2011-126.html</guid>
										<title>2004 - 2009 Cadillac XLR and XLR-V: Service Bulletin: #PIP4245A: Torque Tube Fully Serviceable - (Jun 20, 2011)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-and-xlr-v-service-bulletin-pip4245a-torque-tube-fully-serviceable-jun-20-2011-126.html</link>
										<description><![CDATA[#PIP4245A: Torque Tube Fully Serviceable - (Jun 20, 2011)    Subject:&nbsp; Torque Tube Fully Serviceable   Models:&nbsp; 2004 - 2009 Cadillac XLR, XLR-V   1997 - 2011 Chevrolet Corvette, Corvette Z06   2009 - 2011 Chevrolet Corvette ZR1     This PI...]]></description>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-info-automatic-transmission-shift-engine-driveability-concerns-or-service-engine-soon-ses-light-on-57.html</guid>
										<title>2004 - 2007 Cadillac XLR: Service Info: Automatic Transmission Shift, Engine Driveability Concerns or Service Engine Soon (SES) Light On</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-info-automatic-transmission-shift-engine-driveability-concerns-or-service-engine-soon-ses-light-on-57.html</link>
										<description><![CDATA[#04-07-30-013B: Info - Automatic Transmission Shift, Engine Driveability Concerns or Service Engine Soon (SES) Light On as a Result of the Use of an Excessively/Over-Oiled Aftermarket, Reusable Air Filter - (Feb 1, 2007) Subject: Automatic...]]></description>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-gm-techlink-fuel-line-quick-connectors-102.html</guid>
										<title>2004 - 2005 Cadillac XLR: GM TechLink: Fuel Line Quick Connectors</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-gm-techlink-fuel-line-quick-connectors-102.html</link>
										<description><![CDATA[From GM TechLink, February 2004: Two new style fuel line quick connects are in use. The TI Group Global Quick Connector is used on C/K trucks, S/T trucks, Malibu Sedan, Cadillac XLR and the 2004.5 and 2005 Chevrolet Corvette. The Legris QC is used on...]]></description>
