<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-16-na-130-no-reverse-no-second-after-upper-valve-body-replacement-10.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-pip5429-2-3-upshift-slip-or-flare-oct-10-2016-104.html</guid>
										<title>2006 - 2009 Cadillac XLR - XLR-V: Service Bulletin: #PIP5429: 2-3 Upshift Slip or Flare - (Oct 10, 2016)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-pip5429-2-3-upshift-slip-or-flare-oct-10-2016-104.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-service-bulletin-pi0299-harsh-shifts-after-replacement-of-1-2-3-4-3-5-r-clutch-housing-149.html</guid>
										<title>2006 - 2009 Cadillac XLR: Service Bulletin: #PI0299: Harsh Shifts After Replacement of 1-2-3-4 / 3-5-R Clutch Housing</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-service-bulletin-pi0299-harsh-shifts-after-replacement-of-1-2-3-4-3-5-r-clutch-housing-149.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-service-bulletin-pip3233-2004-cadillac-srx-and-xlr-5l50e-no-fourth-or-fifth-gear-20.html</guid>
										<title>2004 Cadillac XLR: Service Bulletin: #PIP3233: 2004 Cadillac SRX and XLR 5L50E No Fourth or Fifth Gear</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-service-bulletin-pip3233-2004-cadillac-srx-and-xlr-5l50e-no-fourth-or-fifth-gear-20.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2008-cadillac-xlr-and-xlr-v-techlink-article-shift-to-park-message-90.html</guid>
										<title>2004 - 2008 Cadillac XLR and XLR-V: TechLink Article: &quot;Shift to Park&quot; Message</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2008-cadillac-xlr-and-xlr-v-techlink-article-shift-to-park-message-90.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-v-service-bulletin-pi0773-diagnostic-tips-for-dtc-p0796-slip-or-no-4th-5th-or-6th-gear-jul-25-2012-118.html</guid>
										<title>2006 - 2009 Cadillac XLR-V: Service Bulletin: #PI0773: Diagnostic Tips for DTC P0796, Slip or No 4th, 5th or 6th Gear - (Jul 25, 2012)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-v-service-bulletin-pi0773-diagnostic-tips-for-dtc-p0796-slip-or-no-4th-5th-or-6th-gear-jul-25-2012-118.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-01-07-30-032e-transmission-oil-leaking-from-transmission-vent-129.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #01-07-30-032E: Transmission Oil Leaking From Transmission Vent</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-01-07-30-032e-transmission-oil-leaking-from-transmission-vent-129.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-v-service-bulletin-automatic-transmission-busy-shifting-mil-illuminated-dtc-p1751-61.html</guid>
										<title>2006 Cadillac XLR-V: Service Bulletin: Automatic Transmission, Busy Shifting, MIL Illuminated, DTC P1751</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-v-service-bulletin-automatic-transmission-busy-shifting-mil-illuminated-dtc-p1751-61.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-pip4112q-normal-characteristic-sag-or-hesitation-on-acceleration-9.html</guid>
										<title>2006 - 2009 Cadillac XLR XLR-V: Service Bulletin: #PIP4112Q: Normal Characteristic - Sag Or Hesitation On Acceleration</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-pip4112q-normal-characteristic-sag-or-hesitation-on-acceleration-9.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/september-5-2002-gm-powertrain-to-debut-new-hydra-matic-5-speed-85.html</guid>
										<title>September 5, 2002:  GM Powertrain to Debut New Hydra-Matic 5-Speed</title>
										<link>https://www.xlr-net.com/knowledgebase/article/september-5-2002-gm-powertrain-to-debut-new-hydra-matic-5-speed-85.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-5l50-e-transmission-identification-and-vin-derivative-location-17.html</guid>
										<title>2004 - 2009 Cadillac XLR: 5L50-E Transmission Identification and VIN Derivative Location</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-5l50-e-transmission-identification-and-vin-derivative-location-17.html</link>
