										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-information-no-crank-prndl-inoperative-98.html</guid>
										<title>2004 - 2005 Cadillac XLR: Service Information: No Crank, PRNDL Inoperative</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-information-no-crank-prndl-inoperative-98.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-2008-cadillac-xlr-techlink-article-fob-conditions-69.html</guid>
										<title>2005 - 2008 Cadillac XLR: TechLink Article: Fob Conditions</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-2008-cadillac-xlr-techlink-article-fob-conditions-69.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2006-cadillac-xlr-service-bulletin-pic3865b-intermittent-poor-and-or-no-radio-reception-fm-stations-jul-11-2013-105.html</guid>
										<title>2004 - 2006 Cadillac XLR:  Service Bulletin:  #PIC3865B: Intermittent Poor and/or No Radio Reception FM Stations - (Jul 11, 2013)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2006-cadillac-xlr-service-bulletin-pic3865b-intermittent-poor-and-or-no-radio-reception-fm-stations-jul-11-2013-105.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-gm-techlink-no-fob-detected-message-81.html</guid>
										<title>2004 - 2009 Cadillac XLR:  GM TechLink:  No Fob Detected Message</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-gm-techlink-no-fob-detected-message-81.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-and-xlr-v-service-bulletin-pic3225j-set-up-rcdlr-after-replacement-143.html</guid>
										<title>2004 - 2009 Cadillac XLR and XLR-V: Service Bulletin: #PIC3225J: Set Up RCDLR After Replacement</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-and-xlr-v-service-bulletin-pic3225j-set-up-rcdlr-after-replacement-143.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-service-information-high-mount-stop-lamp-replacement-58.html</guid>
										<title>2006 Cadillac XLR: Service Information: High Mount Stop Lamp Replacement</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-service-information-high-mount-stop-lamp-replacement-58.html</link>
