<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-07-08-49-020l-ipc-odometer-programming-method-quick-reference-guide-jan-6-2017-108.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2007-2009-cadillac-xlr-service-bulletin-pic4510c-onstar®-tbt-turn-by-turn-and-digit-display-location-jul-18-2012-119.html</guid>
										<title>2007 - 2009 Cadillac XLR: Service Bulletin: #PIC4510C: OnStar® TBT (Turn by Turn) And Digit Display Location - (Jul 18, 2012)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2007-2009-cadillac-xlr-service-bulletin-pic4510c-onstar®-tbt-turn-by-turn-and-digit-display-location-jul-18-2012-119.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/20004-2009-cadillac-xlr-service-information-pic4879a-heads-up-display-inoperative-132.html</guid>
										<title>20004 - 2009 Cadillac XLR: Service Information: #PIC4879A: Heads Up Display Inoperative</title>
										<link>https://www.xlr-net.com/knowledgebase/article/20004-2009-cadillac-xlr-service-information-pic4879a-heads-up-display-inoperative-132.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-and-xlr-v-service-bulletin-pic3225j-set-up-rcdlr-after-replacement-143.html</guid>
										<title>2004 - 2009 Cadillac XLR and XLR-V: Service Bulletin: #PIC3225J: Set Up RCDLR After Replacement</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-and-xlr-v-service-bulletin-pic3225j-set-up-rcdlr-after-replacement-143.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-gm-techlink-article-ebcm-condition-50.html</guid>
										<title>2009 Cadillac XLR: GM TechLink Article: EBCM Condition</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-gm-techlink-article-ebcm-condition-50.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-xlr-v-recall-notice-15643-special-coverage-adjustment-airbag-light-on-8.html</guid>
										<title>2004 - 2009 Cadillac XLR XLR-V: Recall Notice: #15643: Special Coverage Adjustment - Airbag Light On</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-xlr-v-recall-notice-15643-special-coverage-adjustment-airbag-light-on-8.html</link>
