<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic4858a-navigation-radio-cd-error-cd-player-will-not-accept-discs-feb-11-2013-109.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-bose-sound-system-82.html</guid>
										<title>2004 - 2009 Cadillac XLR:  Bose Sound System</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-bose-sound-system-82.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-bulletin-revised-fuel-sender-values-93.html</guid>
										<title>2004 - 2007 Cadillac XLR: Service Bulletin: Revised Fuel Sender Values</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-bulletin-revised-fuel-sender-values-93.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-information-low-or-completely-discharged-battery-99.html</guid>
										<title>2004 - 2005 Cadillac XLR: Service Information: Low or Completely Discharged Battery</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-information-low-or-completely-discharged-battery-99.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2008-cadillac-xlr-service-bulletin-change-in-the-gm-nav-disc-update-program-54.html</guid>
										<title>2008 Cadillac XLR: Service Bulletin: Change in the GM Nav Disc Update Program</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2008-cadillac-xlr-service-bulletin-change-in-the-gm-nav-disc-update-program-54.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-diagnostic-tip-difficulty-programming-modules-cannot-achieve-ignition-on-engine-off-mode-6.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: Diagnostic Tip - Difficulty Programming Modules, Cannot Achieve Ignition On, Engine Off Mode</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-diagnostic-tip-difficulty-programming-modules-cannot-achieve-ignition-on-engine-off-mode-6.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-07-08-49-020l-ipc-odometer-programming-method-quick-reference-guide-jan-6-2017-108.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #07-08-49-020L: IPC Odometer Programming Method Quick Reference Guide - (Jan 6, 2017)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-07-08-49-020l-ipc-odometer-programming-method-quick-reference-guide-jan-6-2017-108.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2008-cadillac-xlr-techlink-article-door-handle-release-button-88.html</guid>
										<title>2004 - 2008 Cadillac XLR: TechLink Article: Door Handle Release Button</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2008-cadillac-xlr-techlink-article-door-handle-release-button-88.html</link>
