<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-ipc-odometer-programming-method-quick-reference-guide-11.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-xm-antenna-installation-on-xlr-71.html</guid>
										<title>2004 Cadillac XLR: XM Antenna Installation on XLR</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-bose-sound-system-82.html</guid>
										<title>2004 - 2009 Cadillac XLR:  Bose Sound System</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-bose-sound-system-82.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-radio-does-not-mute-enough-when-onstar-turn-by-turn-navigation-directions-are-announced-24.html</guid>
										<title>2009 Cadillac XLR: Service Bulletin: Radio Does Not Mute Enough When OnStar Turn-By-Turn Navigation Directions Are Announced</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic4858a-navigation-radio-cd-error-cd-player-will-not-accept-discs-feb-11-2013-109.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #PIC4858A: Navigation Radio CD Error - CD Player Will Not Accept Discs - (Feb 11, 2013)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic4858a-navigation-radio-cd-error-cd-player-will-not-accept-discs-feb-11-2013-109.html</link>
