										<guid>https://www.xlr-net.com/knowledgebase/article/20004-2009-cadillac-xlr-service-information-pic4879a-heads-up-display-inoperative-132.html</guid>
										<title>20004 - 2009 Cadillac XLR: Service Information: #PIC4879A: Heads Up Display Inoperative</title>
										<link>https://www.xlr-net.com/knowledgebase/article/20004-2009-cadillac-xlr-service-information-pic4879a-heads-up-display-inoperative-132.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-bose-sound-system-82.html</guid>
										<title>2004 - 2009 Cadillac XLR:  Bose Sound System</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-bose-sound-system-82.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic5426-navigation-system-identifies-destination-location-on-opposite-side-of-road-148.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #PIC5426: Navigation System Identifies Destination Location On Opposite Side Of Road</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic5426-navigation-system-identifies-destination-location-on-opposite-side-of-road-148.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-information-low-or-completely-discharged-battery-99.html</guid>
										<title>2004 - 2005 Cadillac XLR: Service Information: Low or Completely Discharged Battery</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-information-low-or-completely-discharged-battery-99.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-and-xlr-v-service-bulletin-pit4617-express-window-up-feature-inoperative-after-using-retractable-roof-137.html</guid>
										<title>2009 Cadillac XLR and XLR-V: Service Bulletin: #PIT4617: Express Window Up Feature Inoperative After Using Retractable Roof</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-radio-does-not-mute-enough-when-onstar-turn-by-turn-navigation-directions-are-announced-24.html</guid>
										<title>2009 Cadillac XLR: Service Bulletin: Radio Does Not Mute Enough When OnStar Turn-By-Turn Navigation Directions Are Announced</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic5961-no-fob-detected-message-on-dic-possible-no-crank-start-144.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #PIC5961: NO FOB DETECTED Message On DIC Possible No Crank Start</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic5961-no-fob-detected-message-on-dic-possible-no-crank-start-144.html</link>
