<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic3379d-hud-head-up-display-information-multiple-conditions-or-questions-nov-27-2012-113.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-bulletin-erratic-fuel-gauge-readings-fuel-gauge-reads-empty-when-there-is-fuel-in-tank-100.html</guid>
										<title>2004 - 2005 Cadillac XLR: Service Bulletin: Erratic Fuel Gauge Readings, Fuel Gauge Reads Empty When There Is Fuel In Tank</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-bulletin-erratic-fuel-gauge-readings-fuel-gauge-reads-empty-when-there-is-fuel-in-tank-100.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-2007-cadillac-xlr-and-xlr-v-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-70.html</guid>
										<title>2005 - 2007 Cadillac XLR and XLR-V: Service Bulletin: Intermittent Service Stability Message On DIC With Only DTC C0561 Symptom 71</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-2007-cadillac-xlr-and-xlr-v-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-70.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-and-xlr-v-service-bulletin-pic3225j-set-up-rcdlr-after-replacement-143.html</guid>
										<title>2004 - 2009 Cadillac XLR and XLR-V: Service Bulletin: #PIC3225J: Set Up RCDLR After Replacement</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-and-xlr-v-service-bulletin-pic3225j-set-up-rcdlr-after-replacement-143.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-information-pic4673a-horn-sounds-unwanted-134.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Information:  #PIC4673A: Horn Sounds Unwanted</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-information-pic4673a-horn-sounds-unwanted-134.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-service-information-high-mount-stop-lamp-replacement-58.html</guid>
										<title>2006 Cadillac XLR: Service Information: High Mount Stop Lamp Replacement</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-service-information-high-mount-stop-lamp-replacement-58.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2008-2009-cadillac-xlr-service-bulletin-08-09-41-002h-diagnostic-information-for-supplemental-inflatable-restraint-sir-system-intermittent-air-bag-indicator-lamp-illuminated-4.html</guid>
										<title>2008 - 2009 Cadillac XLR:  Service Bulletin: #08-09-41-002H: Diagnostic Information for Supplemental Inflatable Restraint (SIR) System, Intermittent AIR BAG Indicator/Lamp Illuminated</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2008-2009-cadillac-xlr-service-bulletin-08-09-41-002h-diagnostic-information-for-supplemental-inflatable-restraint-sir-system-intermittent-air-bag-indicator-lamp-illuminated-4.html</link>
