<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic5049a-fuel-tank-hard-to-fill-or-displays-1-2-tank-after-filling-oct-22-2012-114.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-07-08-49-020l-ipc-odometer-programming-method-quick-reference-guide-jan-6-2017-108.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #07-08-49-020L: IPC Odometer Programming Method Quick Reference Guide - (Jan 6, 2017)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-07-08-49-020l-ipc-odometer-programming-method-quick-reference-guide-jan-6-2017-108.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2007-2009-cadillac-xlr-service-bulletin-pic4510c-onstar®-tbt-turn-by-turn-and-digit-display-location-jul-18-2012-119.html</guid>
										<title>2007 - 2009 Cadillac XLR: Service Bulletin: #PIC4510C: OnStar® TBT (Turn by Turn) And Digit Display Location - (Jul 18, 2012)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2007-2009-cadillac-xlr-service-bulletin-pic4510c-onstar®-tbt-turn-by-turn-and-digit-display-location-jul-18-2012-119.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-xlr-v-recall-notice-15643-special-coverage-adjustment-airbag-light-on-8.html</guid>
										<title>2004 - 2009 Cadillac XLR XLR-V: Recall Notice: #15643: Special Coverage Adjustment - Airbag Light On</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-xlr-v-recall-notice-15643-special-coverage-adjustment-airbag-light-on-8.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-service-information-high-mount-stop-lamp-replacement-58.html</guid>
										<title>2006 Cadillac XLR: Service Information: High Mount Stop Lamp Replacement</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-service-information-high-mount-stop-lamp-replacement-58.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-ipc-odometer-programming-method-quick-reference-guide-11.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: IPC Odometer Programming Method Quick Reference Guide</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-ipc-odometer-programming-method-quick-reference-guide-11.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-xm-antenna-installation-on-xlr-71.html</guid>
										<title>2004 Cadillac XLR: XM Antenna Installation on XLR</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-bulletin-revised-fuel-sender-values-93.html</guid>
										<title>2004 - 2007 Cadillac XLR: Service Bulletin: Revised Fuel Sender Values</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-bulletin-revised-fuel-sender-values-93.html</link>
