										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-xm-antenna-installation-on-xlr-71.html</guid>
										<title>2004 Cadillac XLR: XM Antenna Installation on XLR</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-cadillac-xlr-gm-techlink-keyless-ignition-system-65.html</guid>
										<title>2005 Cadillac XLR: GM TechLink: Keyless Ignition System</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-cadillac-xlr-gm-techlink-keyless-ignition-system-65.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-2007-cadillac-xlr-and-xlr-v-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-70.html</guid>
										<title>2005 - 2007 Cadillac XLR and XLR-V: Service Bulletin: Intermittent Service Stability Message On DIC With Only DTC C0561 Symptom 71</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-2007-cadillac-xlr-and-xlr-v-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-70.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2006-cadillac-xlr-service-bulletin-pic3865b-intermittent-poor-and-or-no-radio-reception-fm-stations-jul-11-2013-105.html</guid>
										<title>2004 - 2006 Cadillac XLR:  Service Bulletin:  #PIC3865B: Intermittent Poor and/or No Radio Reception FM Stations - (Jul 11, 2013)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2006-cadillac-xlr-service-bulletin-pic3865b-intermittent-poor-and-or-no-radio-reception-fm-stations-jul-11-2013-105.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2007-2009-cadillac-xlr-service-bulletin-pic5375-fuel-gauge-pump-diagnostic-tests-oct-13-2010-147.html</guid>
										<title>2007 - 2009 Cadillac XLR: Service Bulletin:  #PIC5375: Fuel Gauge / Pump Diagnostic Tests - (Oct 13, 2010)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2007-2009-cadillac-xlr-service-bulletin-pic5375-fuel-gauge-pump-diagnostic-tests-oct-13-2010-147.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/20004-2009-cadillac-xlr-service-information-pic4879a-heads-up-display-inoperative-132.html</guid>
										<title>20004 - 2009 Cadillac XLR: Service Information: #PIC4879A: Heads Up Display Inoperative</title>
										<link>https://www.xlr-net.com/knowledgebase/article/20004-2009-cadillac-xlr-service-information-pic4879a-heads-up-display-inoperative-132.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-07-08-49-020l-ipc-odometer-programming-method-quick-reference-guide-jan-6-2017-108.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #07-08-49-020L: IPC Odometer Programming Method Quick Reference Guide - (Jan 6, 2017)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-07-08-49-020l-ipc-odometer-programming-method-quick-reference-guide-jan-6-2017-108.html</link>
