<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-pip4112r-normal-characteristic-sag-or-hesitation-on-acceleration-mar-24-2017-123.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-service-bulletin-pi01243-extended-crank-time-4-6-ignition-pcm-performance-start-starter-switch-jul-23-2003-116.html</guid>
										<title>2004 Cadillac XLR:  Service Bulletin:  #PI01243: Extended Crank Time - 4.6 ignition PCM performance start starter switch - (Jul 23, 2003)</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-and-xlr-v-service-bulletin-pip4245a-torque-tube-fully-serviceable-jun-20-2011-126.html</guid>
										<title>2004 - 2009 Cadillac XLR and XLR-V: Service Bulletin: #PIP4245A: Torque Tube Fully Serviceable - (Jun 20, 2011)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-and-xlr-v-service-bulletin-pip4245a-torque-tube-fully-serviceable-jun-20-2011-126.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-v-service-bulletin-pip4493-ses-light-due-to-dtcs-p0171-and-or-p0174-inspect-air-cleaner-outlet-duct-and-supercharger-inlet-duct-clamps-152.html</guid>
										<title>2006 - 2009 Cadillac XLR-V: Service Bulletin: #PIP4493: SES Light due to DTCs P0171 and/or P0174 - Inspect Air Cleaner Outlet Duct and Supercharger Inlet Duct Clamps</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-v-service-bulletin-pip4493-ses-light-due-to-dtcs-p0171-and-or-p0174-inspect-air-cleaner-outlet-duct-and-supercharger-inlet-duct-clamps-152.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-gm-techlink-fuel-line-quick-connectors-102.html</guid>
										<title>2004 - 2005 Cadillac XLR: GM TechLink: Fuel Line Quick Connectors</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-gm-techlink-fuel-line-quick-connectors-102.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-info-automatic-transmission-shift-engine-driveability-concerns-or-service-engine-soon-ses-light-on-57.html</guid>
										<title>2004 - 2007 Cadillac XLR: Service Info: Automatic Transmission Shift, Engine Driveability Concerns or Service Engine Soon (SES) Light On</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-info-automatic-transmission-shift-engine-driveability-concerns-or-service-engine-soon-ses-light-on-57.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-v-techlink-article-supercharging-explained-62.html</guid>
										<title>2006 - 2009 Cadillac XLR-V: TechLink Article: Supercharging Explained</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-v-techlink-article-supercharging-explained-62.html</link>
