										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-v-techlink-article-supercharging-explained-62.html</guid>
										<title>2006 - 2009 Cadillac XLR-V: TechLink Article: Supercharging Explained</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-v-techlink-article-supercharging-explained-62.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-and-xlr-v-service-bulletin-pic4050a-whine-noise-from-power-steering-at-cold-start-138.html</guid>
										<title>2006 - 2009 Cadillac XLR and XLR-V: Service Bulletin: #PIC4050A: Whine Noise from Power Steering at Cold Start</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-and-xlr-v-service-bulletin-pic4050a-whine-noise-from-power-steering-at-cold-start-138.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-and-xlr-v-service-bulletin-pip4245a-torque-tube-fully-serviceable-jun-20-2011-126.html</guid>
										<title>2004 - 2009 Cadillac XLR and XLR-V: Service Bulletin: #PIP4245A: Torque Tube Fully Serviceable - (Jun 20, 2011)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-and-xlr-v-service-bulletin-pip4245a-torque-tube-fully-serviceable-jun-20-2011-126.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-pip4112q-normal-characteristic-sag-or-hesitation-on-acceleration-9.html</guid>
										<title>2006 - 2009 Cadillac XLR XLR-V: Service Bulletin: #PIP4112Q: Normal Characteristic - Sag Or Hesitation On Acceleration</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-pip4112q-normal-characteristic-sag-or-hesitation-on-acceleration-9.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-service-bulletin-pi01243-extended-crank-time-4-6-ignition-pcm-performance-start-starter-switch-jul-23-2003-116.html</guid>
										<title>2004 Cadillac XLR:  Service Bulletin:  #PI01243: Extended Crank Time - 4.6 ignition PCM performance start starter switch - (Jul 23, 2003)</title>
