<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-information-pic4693b-navigation-radio-clock-inaccurate-by-1-hour-135.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-16-na-055-information-regarding-servicing-components-located-near-sir-components-22.html</guid>
										<title>2009 Cadillac XLR: Service Bulletin: #16-NA-055: Information Regarding Servicing Components Located Near SIR Components</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-information-no-crank-prndl-inoperative-98.html</guid>
										<title>2004 - 2005 Cadillac XLR: Service Information: No Crank, PRNDL Inoperative</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-information-no-crank-prndl-inoperative-98.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-ipc-odometer-programming-method-quick-reference-guide-11.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: IPC Odometer Programming Method Quick Reference Guide</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-ipc-odometer-programming-method-quick-reference-guide-11.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-bulletin-revised-fuel-sender-values-93.html</guid>
										<title>2004 - 2007 Cadillac XLR: Service Bulletin: Revised Fuel Sender Values</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-bulletin-revised-fuel-sender-values-93.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-bulletin-poor-or-no-gps-reception-13.html</guid>
										<title>2004 - 2005 Cadillac XLR: Service Bulletin: Poor or No GPS reception</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-bulletin-poor-or-no-gps-reception-13.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-gm-tech-link-bluetooth-issues-49.html</guid>
										<title>2009 Cadillac XLR: GM Tech Link: Bluetooth Issues</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-gm-tech-link-bluetooth-issues-49.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-techlink-article-noticeable-difference-in-audio-volume-level-67.html</guid>
										<title>2005 - 2009 Cadillac XLR: TechLink Article: Noticeable Difference in Audio Volume Level</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-techlink-article-noticeable-difference-in-audio-volume-level-67.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic3379d-hud-head-up-display-information-multiple-conditions-or-questions-nov-27-2012-113.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #PIC3379D: HUD - Head Up Display Information - Multiple Conditions or Questions - (Nov 27, 2012)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic3379d-hud-head-up-display-information-multiple-conditions-or-questions-nov-27-2012-113.html</link>
