										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-xlr-v-recall-notice-15643-special-coverage-adjustment-airbag-light-on-8.html</guid>
										<title>2004 - 2009 Cadillac XLR XLR-V: Recall Notice: #15643: Special Coverage Adjustment - Airbag Light On</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-xlr-v-recall-notice-15643-special-coverage-adjustment-airbag-light-on-8.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-resetting-the-engine-oil-life-monitor-76.html</guid>
										<title>2004 Cadillac XLR: Resetting the Engine Oil Life Monitor</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-resetting-the-engine-oil-life-monitor-76.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2008-cadillac-xlr-service-bulletin-change-in-the-gm-nav-disc-update-program-54.html</guid>
										<title>2008 Cadillac XLR: Service Bulletin: Change in the GM Nav Disc Update Program</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2008-cadillac-xlr-service-bulletin-change-in-the-gm-nav-disc-update-program-54.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-gm-techlink-special-edition-paint-codes-79.html</guid>
										<title>2004 Cadillac XLR:  GM TechLink:  Special Edition Paint Codes</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-gm-techlink-special-edition-paint-codes-79.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-gm-techlink-power-folding-top-diagnostic-tips-160.html</guid>
										<title>2004 - 2009 Cadillac XLR: GM TechLink: Power Folding Top Diagnostic Tips</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-gm-techlink-power-folding-top-diagnostic-tips-160.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-techlink-article-noticeable-difference-in-audio-volume-level-67.html</guid>
										<title>2005 - 2009 Cadillac XLR: TechLink Article: Noticeable Difference in Audio Volume Level</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-techlink-article-noticeable-difference-in-audio-volume-level-67.html</link>
