<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-and-xlr-v-service-bulletin-pic4050a-whine-noise-from-power-steering-at-cold-start-138.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-gm-techlink-fuel-line-quick-connectors-102.html</guid>
										<title>2004 - 2005 Cadillac XLR: GM TechLink: Fuel Line Quick Connectors</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-gm-techlink-fuel-line-quick-connectors-102.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-service-bulletin-pi01243-extended-crank-time-4-6-ignition-pcm-performance-start-starter-switch-jul-23-2003-116.html</guid>
										<title>2004 Cadillac XLR:  Service Bulletin:  #PI01243: Extended Crank Time - 4.6 ignition PCM performance start starter switch - (Jul 23, 2003)</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-info-automatic-transmission-shift-engine-driveability-concerns-or-service-engine-soon-ses-light-on-57.html</guid>
										<title>2004 - 2007 Cadillac XLR: Service Info: Automatic Transmission Shift, Engine Driveability Concerns or Service Engine Soon (SES) Light On</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-info-automatic-transmission-shift-engine-driveability-concerns-or-service-engine-soon-ses-light-on-57.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-service-information-fuel-tank-system-73.html</guid>
										<title>2004 Cadillac XLR: Service Information: Fuel Tank System</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-service-information-fuel-tank-system-73.html</link>
