										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-recall-notice-lower-control-arm-ball-stud-washer-75.html</guid>
										<title>2004 Cadillac XLR: Recall Notice: Lower Control Arm Ball Stud Washer</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-info-automatic-transmission-shift-engine-driveability-concerns-or-service-engine-soon-ses-light-on-57.html</guid>
										<title>2004 - 2007 Cadillac XLR: Service Info: Automatic Transmission Shift, Engine Driveability Concerns or Service Engine Soon (SES) Light On</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-info-automatic-transmission-shift-engine-driveability-concerns-or-service-engine-soon-ses-light-on-57.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-service-bulletin-tapping-or-scraping-noise-from-rear-wheel-area-68.html</guid>
										<title>2005 - 2009 Cadillac XLR:  Service Bulletin:  Tapping or Scraping Noise From Rear Wheel Area</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-service-bulletin-tapping-or-scraping-noise-from-rear-wheel-area-68.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-pip4112q-normal-characteristic-sag-or-hesitation-on-acceleration-9.html</guid>
										<title>2006 - 2009 Cadillac XLR XLR-V: Service Bulletin: #PIP4112Q: Normal Characteristic - Sag Or Hesitation On Acceleration</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-pip4112q-normal-characteristic-sag-or-hesitation-on-acceleration-9.html</link>
