<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic5961-no-fob-detected-message-on-dic-possible-no-crank-start-144.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-information-pic4673a-horn-sounds-unwanted-134.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Information:  #PIC4673A: Horn Sounds Unwanted</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-information-pic4673a-horn-sounds-unwanted-134.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-information-no-crank-prndl-inoperative-98.html</guid>
										<title>2004 - 2005 Cadillac XLR: Service Information: No Crank, PRNDL Inoperative</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-information-no-crank-prndl-inoperative-98.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-information-low-or-completely-discharged-battery-99.html</guid>
										<title>2004 - 2005 Cadillac XLR: Service Information: Low or Completely Discharged Battery</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-information-low-or-completely-discharged-battery-99.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic4762a-dic-does-not-display-auto-recall-or-auto-exit-recall-154.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #PIC4762A: DIC Does Not Display Auto Recall or Auto Exit Recall</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic4762a-dic-does-not-display-auto-recall-or-auto-exit-recall-154.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2008-cadillac-xlr-techlink-article-door-handle-release-button-88.html</guid>
										<title>2004 - 2008 Cadillac XLR: TechLink Article: Door Handle Release Button</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2008-cadillac-xlr-techlink-article-door-handle-release-button-88.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2008-cadillac-xlr-and-xlr-v-techlink-article-shift-to-park-message-90.html</guid>
										<title>2004 - 2008 Cadillac XLR and XLR-V: TechLink Article: &quot;Shift to Park&quot; Message</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2008-cadillac-xlr-and-xlr-v-techlink-article-shift-to-park-message-90.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-resetting-the-engine-oil-life-monitor-76.html</guid>
										<title>2004 Cadillac XLR: Resetting the Engine Oil Life Monitor</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-resetting-the-engine-oil-life-monitor-76.html</link>
