										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-pi0086e-unexpected-loss-of-radio-audio-radio-goes-silent-no-sound-and-other-blackberry-phone-bluetooth-issues-106.html</guid>
										<title>2009 Cadillac XLR: Service Bulletin: #PI0086E: Unexpected Loss of Radio Audio (Radio Goes Silent/No Sound) and Other Blackberry Phone - Bluetooth Issues</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-pi0086e-unexpected-loss-of-radio-audio-radio-goes-silent-no-sound-and-other-blackberry-phone-bluetooth-issues-106.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-16-na-055-information-regarding-servicing-components-located-near-sir-components-22.html</guid>
										<title>2009 Cadillac XLR: Service Bulletin: #16-NA-055: Information Regarding Servicing Components Located Near SIR Components</title>
