										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-xm-antenna-installation-on-xlr-71.html</guid>
										<title>2004 Cadillac XLR: XM Antenna Installation on XLR</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-bulletin-folding-top-inop-and-or-dtc-b1310-19.html</guid>
										<title>2004 - 2005 Cadillac XLR: Service Bulletin: Folding Top Inop and/or DTC B1310</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-bulletin-folding-top-inop-and-or-dtc-b1310-19.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2008-cadillac-xlr-techlink-article-door-handle-release-button-88.html</guid>
										<title>2004 - 2008 Cadillac XLR: TechLink Article: Door Handle Release Button</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2008-cadillac-xlr-techlink-article-door-handle-release-button-88.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-cadillac-xlr-gm-techlink-keyless-ignition-system-65.html</guid>
										<title>2005 Cadillac XLR: GM TechLink: Keyless Ignition System</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-cadillac-xlr-gm-techlink-keyless-ignition-system-65.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-and-xlr-v-service-bulletin-pit4617-express-window-up-feature-inoperative-after-using-retractable-roof-137.html</guid>
										<title>2009 Cadillac XLR and XLR-V: Service Bulletin: #PIT4617: Express Window Up Feature Inoperative After Using Retractable Roof</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2008-cadillac-xlr-service-bulletin-change-in-the-gm-nav-disc-update-program-54.html</guid>
										<title>2008 Cadillac XLR: Service Bulletin: Change in the GM Nav Disc Update Program</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2008-cadillac-xlr-service-bulletin-change-in-the-gm-nav-disc-update-program-54.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-15643a-special-coverage-airbag-light-on-feb-2-2017-110.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #15643A: Special Coverage - Airbag Light On - (Feb 2, 2017)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-15643a-special-coverage-airbag-light-on-feb-2-2017-110.html</link>
