<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic5426-navigation-system-identifies-destination-location-on-opposite-side-of-road-148.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-service-bulletin-language-change-for-onstar-system-u-s-only-59.html</guid>
										<title>2006 Cadillac XLR: Service Bulletin: Language Change for OnStar System (U.S. Only)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-service-bulletin-language-change-for-onstar-system-u-s-only-59.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-10-08-52-004-diag-info-on-no-remote-detected-no-fobs-detected-message-on-dic-electrical-interference-with-cell-phone-or-other-12-volt-charger-plugged-in-150.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #10-08-52-004: Diag Info on No Remote Detected/No Fobs Detected Message on DIC/Electrical Interference with Cell Phone or Other 12 Volt Charger Plugged In</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-10-08-52-004-diag-info-on-no-remote-detected-no-fobs-detected-message-on-dic-electrical-interference-with-cell-phone-or-other-12-volt-charger-plugged-in-150.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-pit4683f-additional-wheel-speed-sensor-diagnostics-jul-31-2012-115.html</guid>
										<title>2009 Cadillac XLR:  Service Bulletin: #PIT4683F: Additional Wheel Speed Sensor Diagnostics - (Jul 31, 2012)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-pit4683f-additional-wheel-speed-sensor-diagnostics-jul-31-2012-115.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2006-cadillac-xlr-service-bulletin-pic3865b-intermittent-poor-and-or-no-radio-reception-fm-stations-jul-11-2013-105.html</guid>
										<title>2004 - 2006 Cadillac XLR:  Service Bulletin:  #PIC3865B: Intermittent Poor and/or No Radio Reception FM Stations - (Jul 11, 2013)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2006-cadillac-xlr-service-bulletin-pic3865b-intermittent-poor-and-or-no-radio-reception-fm-stations-jul-11-2013-105.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-bulletin-erratic-fuel-gauge-readings-fuel-gauge-reads-empty-when-there-is-fuel-in-tank-100.html</guid>
										<title>2004 - 2005 Cadillac XLR: Service Bulletin: Erratic Fuel Gauge Readings, Fuel Gauge Reads Empty When There Is Fuel In Tank</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-bulletin-erratic-fuel-gauge-readings-fuel-gauge-reads-empty-when-there-is-fuel-in-tank-100.html</link>
