<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-v-service-bulletin-pip4493-ses-light-due-to-dtcs-p0171-and-or-p0174-inspect-air-cleaner-outlet-duct-and-supercharger-inlet-duct-clamps-152.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-info-automatic-transmission-shift-engine-driveability-concerns-or-service-engine-soon-ses-light-on-57.html</guid>
										<title>2004 - 2007 Cadillac XLR: Service Info: Automatic Transmission Shift, Engine Driveability Concerns or Service Engine Soon (SES) Light On</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-info-automatic-transmission-shift-engine-driveability-concerns-or-service-engine-soon-ses-light-on-57.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/september-5-2002-gm-s-livonia-engine-plant-committed-to-quality-83.html</guid>
										<title>September 5, 2002:  GM`s Livonia Engine Plant Committed to Quality</title>
										<link>https://www.xlr-net.com/knowledgebase/article/september-5-2002-gm-s-livonia-engine-plant-committed-to-quality-83.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-recall-special-coverage-adjustment-fuel-tank-quick-connector-leak-77.html</guid>
										<title>2004 Cadillac XLR:  Recall: Special Coverage Adjustment - Fuel Tank Quick Connector Leak</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-recall-special-coverage-adjustment-fuel-tank-quick-connector-leak-77.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-pip4112r-normal-characteristic-sag-or-hesitation-on-acceleration-mar-24-2017-123.html</guid>
										<title>2006 - 2009 Cadillac XLR - XLR-V: Service Bulletin: #PIP4112R: Normal Characteristic - Sag Or Hesitation On Acceleration - (Mar 24, 2017)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-pip4112r-normal-characteristic-sag-or-hesitation-on-acceleration-mar-24-2017-123.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-and-xlr-v-service-bulletin-pic4050a-whine-noise-from-power-steering-at-cold-start-138.html</guid>
										<title>2006 - 2009 Cadillac XLR and XLR-V: Service Bulletin: #PIC4050A: Whine Noise from Power Steering at Cold Start</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-and-xlr-v-service-bulletin-pic4050a-whine-noise-from-power-steering-at-cold-start-138.html</link>
