<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic4762a-dic-does-not-display-auto-recall-or-auto-exit-recall-154.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-and-xlr-v-service-bulletin-pit4617-express-window-up-feature-inoperative-after-using-retractable-roof-137.html</guid>
										<title>2009 Cadillac XLR and XLR-V: Service Bulletin: #PIT4617: Express Window Up Feature Inoperative After Using Retractable Roof</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2007-2009-cadillac-xlr-service-bulletin-pic5375-fuel-gauge-pump-diagnostic-tests-oct-13-2010-147.html</guid>
										<title>2007 - 2009 Cadillac XLR: Service Bulletin:  #PIC5375: Fuel Gauge / Pump Diagnostic Tests - (Oct 13, 2010)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2007-2009-cadillac-xlr-service-bulletin-pic5375-fuel-gauge-pump-diagnostic-tests-oct-13-2010-147.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-resetting-the-engine-oil-life-monitor-76.html</guid>
										<title>2004 Cadillac XLR: Resetting the Engine Oil Life Monitor</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-resetting-the-engine-oil-life-monitor-76.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-bulletin-folding-top-inop-and-or-dtc-b1310-19.html</guid>
										<title>2004 - 2005 Cadillac XLR: Service Bulletin: Folding Top Inop and/or DTC B1310</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-bulletin-folding-top-inop-and-or-dtc-b1310-19.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-red-led-and-b2455-after-performing-canada-upgrade-bulletin-15-08-44-001-7.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: Red LED and B2455 After Performing Canada Upgrade Bulletin 15-08-44-001</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-red-led-and-b2455-after-performing-canada-upgrade-bulletin-15-08-44-001-7.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-onstar-gen-8-xc-module-inoperative-vehicle-battery-discharged-5.html</guid>
										<title>2009 Cadillac XLR: Service Bulletin: OnStar Gen 8.xC Module Inoperative/Vehicle Battery Discharged</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-onstar-gen-8-xc-module-inoperative-vehicle-battery-discharged-5.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-information-no-crank-prndl-inoperative-98.html</guid>
										<title>2004 - 2005 Cadillac XLR: Service Information: No Crank, PRNDL Inoperative</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-information-no-crank-prndl-inoperative-98.html</link>
