										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-gm-techlink-power-folding-top-diagnostic-tips-160.html</guid>
										<title>2004 - 2009 Cadillac XLR: GM TechLink: Power Folding Top Diagnostic Tips</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-gm-techlink-power-folding-top-diagnostic-tips-160.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-gm-tech-link-bluetooth-issues-49.html</guid>
										<title>2009 Cadillac XLR: GM Tech Link: Bluetooth Issues</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-gm-tech-link-bluetooth-issues-49.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-bulletin-erratic-fuel-gauge-readings-fuel-gauge-reads-empty-when-there-is-fuel-in-tank-100.html</guid>
										<title>2004 - 2005 Cadillac XLR: Service Bulletin: Erratic Fuel Gauge Readings, Fuel Gauge Reads Empty When There Is Fuel In Tank</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-bulletin-erratic-fuel-gauge-readings-fuel-gauge-reads-empty-when-there-is-fuel-in-tank-100.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-118-error-when-attempting-to-configure-onstar-use-tbt-or-other-data-services-after-15-08-44-001-upgrade-23.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: 118 Error When Attempting To Configure OnStar, Use TBT, Or Other Data Services After 15-08-44-001 Upgrade</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-118-error-when-attempting-to-configure-onstar-use-tbt-or-other-data-services-after-15-08-44-001-upgrade-23.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-service-bulletin-language-change-for-onstar-system-u-s-only-59.html</guid>
										<title>2006 Cadillac XLR: Service Bulletin: Language Change for OnStar System (U.S. Only)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-service-bulletin-language-change-for-onstar-system-u-s-only-59.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-bose-sound-system-82.html</guid>
										<title>2004 - 2009 Cadillac XLR:  Bose Sound System</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-bose-sound-system-82.html</link>
