										<guid>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-techlink-article-noticeable-difference-in-audio-volume-level-67.html</guid>
										<title>2005 - 2009 Cadillac XLR: TechLink Article: Noticeable Difference in Audio Volume Level</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-techlink-article-noticeable-difference-in-audio-volume-level-67.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-2007-cadillac-xlr-and-xlr-v-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-70.html</guid>
										<title>2005 - 2007 Cadillac XLR and XLR-V: Service Bulletin: Intermittent Service Stability Message On DIC With Only DTC C0561 Symptom 71</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-2007-cadillac-xlr-and-xlr-v-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-70.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic4762a-dic-does-not-display-auto-recall-or-auto-exit-recall-154.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #PIC4762A: DIC Does Not Display Auto Recall or Auto Exit Recall</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic4762a-dic-does-not-display-auto-recall-or-auto-exit-recall-154.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic4858a-navigation-radio-cd-error-cd-player-will-not-accept-discs-feb-11-2013-109.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #PIC4858A: Navigation Radio CD Error - CD Player Will Not Accept Discs - (Feb 11, 2013)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic4858a-navigation-radio-cd-error-cd-player-will-not-accept-discs-feb-11-2013-109.html</link>
