<link>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-service-bulletin-information-on-visual-brake-rotor-surface-cracking-3.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-recall-04086-rear-brake-lining-routing-101.html</guid>
										<title>2004 - 2005 Cadillac XLR: Recall: 04086 -- Rear Brake Lining Routing</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-recall-04086-rear-brake-lining-routing-101.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-bulletin-starts-w-o-brake-input-and-hard-to-shift-out-of-park-14.html</guid>
										<title>2004 - 2005 Cadillac XLR: Service Bulletin: Starts w/o Brake Input and Hard to Shift out of Park</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-bulletin-starts-w-o-brake-input-and-hard-to-shift-out-of-park-14.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-v-service-information-cross-drilled-rotors-66.html</guid>
										<title>2006 Cadillac XLR-V: Service Information: Cross Drilled Rotors</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-v-service-information-cross-drilled-rotors-66.html</link>
