<link>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-gm-tech-link-bluetooth-issues-49.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic4095b-options-not-available-message-displayed-on-the-dic-151.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #PIC4095B: Options Not Available Message Displayed On The DIC</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic4095b-options-not-available-message-displayed-on-the-dic-151.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2007-2009-cadillac-xlr-service-bulletin-pic5375-fuel-gauge-pump-diagnostic-tests-oct-13-2010-147.html</guid>
										<title>2007 - 2009 Cadillac XLR: Service Bulletin:  #PIC5375: Fuel Gauge / Pump Diagnostic Tests - (Oct 13, 2010)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2007-2009-cadillac-xlr-service-bulletin-pic5375-fuel-gauge-pump-diagnostic-tests-oct-13-2010-147.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-2008-cadillac-xlr-techlink-article-fob-conditions-69.html</guid>
										<title>2005 - 2008 Cadillac XLR: TechLink Article: Fob Conditions</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-2008-cadillac-xlr-techlink-article-fob-conditions-69.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-gm-techlink-power-folding-top-diagnostic-tips-160.html</guid>
										<title>2004 - 2009 Cadillac XLR: GM TechLink: Power Folding Top Diagnostic Tips</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-gm-techlink-power-folding-top-diagnostic-tips-160.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/20004-2009-cadillac-xlr-service-information-pic4879a-heads-up-display-inoperative-132.html</guid>
										<title>20004 - 2009 Cadillac XLR: Service Information: #PIC4879A: Heads Up Display Inoperative</title>
										<link>https://www.xlr-net.com/knowledgebase/article/20004-2009-cadillac-xlr-service-information-pic4879a-heads-up-display-inoperative-132.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-15643a-special-coverage-airbag-light-on-feb-2-2017-110.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #15643A: Special Coverage - Airbag Light On - (Feb 2, 2017)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-15643a-special-coverage-airbag-light-on-feb-2-2017-110.html</link>
