<link>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-onstar-gen-8-xc-module-inoperative-vehicle-battery-discharged-5.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-gm-techlink-article-ebcm-condition-50.html</guid>
										<title>2009 Cadillac XLR: GM TechLink Article: EBCM Condition</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-gm-techlink-article-ebcm-condition-50.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-15643a-special-coverage-airbag-light-on-feb-2-2017-110.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #15643A: Special Coverage - Airbag Light On - (Feb 2, 2017)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-15643a-special-coverage-airbag-light-on-feb-2-2017-110.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2008-cadillac-xlr-techlink-article-door-handle-release-button-88.html</guid>
										<title>2004 - 2008 Cadillac XLR: TechLink Article: Door Handle Release Button</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2008-cadillac-xlr-techlink-article-door-handle-release-button-88.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-bulletin-poor-or-no-gps-reception-13.html</guid>
										<title>2004 - 2005 Cadillac XLR: Service Bulletin: Poor or No GPS reception</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-service-bulletin-poor-or-no-gps-reception-13.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-cadillac-xlr-gm-techlink-keyless-ignition-system-65.html</guid>
										<title>2005 Cadillac XLR: GM TechLink: Keyless Ignition System</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-cadillac-xlr-gm-techlink-keyless-ignition-system-65.html</link>
