										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-bulletin-revised-fuel-sender-values-93.html</guid>
										<title>2004 - 2007 Cadillac XLR: Service Bulletin: Revised Fuel Sender Values</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-bulletin-revised-fuel-sender-values-93.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2008-2009-cadillac-xlr-service-bulletin-08-09-41-002h-diagnostic-information-for-supplemental-inflatable-restraint-sir-system-intermittent-air-bag-indicator-lamp-illuminated-4.html</guid>
										<title>2008 - 2009 Cadillac XLR:  Service Bulletin: #08-09-41-002H: Diagnostic Information for Supplemental Inflatable Restraint (SIR) System, Intermittent AIR BAG Indicator/Lamp Illuminated</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2008-2009-cadillac-xlr-service-bulletin-08-09-41-002h-diagnostic-information-for-supplemental-inflatable-restraint-sir-system-intermittent-air-bag-indicator-lamp-illuminated-4.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-information-pic4673a-horn-sounds-unwanted-134.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Information:  #PIC4673A: Horn Sounds Unwanted</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-information-pic4673a-horn-sounds-unwanted-134.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-gm-techlink-article-ebcm-condition-50.html</guid>
										<title>2009 Cadillac XLR: GM TechLink Article: EBCM Condition</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-gm-techlink-article-ebcm-condition-50.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-radio-does-not-mute-enough-when-onstar-turn-by-turn-navigation-directions-are-announced-24.html</guid>
										<title>2009 Cadillac XLR: Service Bulletin: Radio Does Not Mute Enough When OnStar Turn-By-Turn Navigation Directions Are Announced</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic3998b-flash-to-pass-inoperative-with-headlamps-off-158.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #PIC3998B: Flash To Pass Inoperative With Headlamps Off</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic3998b-flash-to-pass-inoperative-with-headlamps-off-158.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-red-led-and-b2455-after-performing-canada-upgrade-bulletin-15-08-44-001-7.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: Red LED and B2455 After Performing Canada Upgrade Bulletin 15-08-44-001</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-red-led-and-b2455-after-performing-canada-upgrade-bulletin-15-08-44-001-7.html</link>
